1999 honda odyssey problems
tigga212, Mar 19, 3:01pm
I have this honda that keeps stalling on me and runs really rough at idle, I've just had to have transmission overhaluled im thinking it maybe fuel but not sure! tia
mugenb20b, Mar 19, 3:37pm
Clean out the throttle body.
accordb20a, Mar 19, 6:53pm
if its just started since the auto was "overhauled" i bet somethings not plugged in correctly.
tigga212, Mar 19, 6:55pm
it has been running rough before the auto transmission was repaired
llortmt, Mar 20, 4:55pm
TPS needs adjusting.
tigga212, Mar 20, 6:03pm
sounds like it will be a trip to the garage!
stoneymeadows, Mar 20, 6:45pm
temporarily block off E.G.R. valve and see if that cures the problem.If it does you may need a new valve.
tigga212, Mar 20, 7:02pm
what do u mean by E.G.R valve!
mugenb20b, Mar 20, 7:04pm
Exhaust gas recirculation valve. It's on the intake manifold, distributor side.
franc123, Mar 20, 7:12pm
Yup EGR valves pretty common to fail on those, I'd look at this before touching anything else.
mugenb20b, Mar 20, 7:15pm
I would still clean the throttle body to start with, it's a 30 second job.
llortmt, Mar 21, 6:08pm
I'd plug it in and look at the TPS.
Is it hunting at idle!
tigga212, Mar 22, 8:57am
have only just checked this thead n see there is a few comment's :) when in idle at a intersection it is running rough, almost feel's like it is going to stall, the engine check light has started coming on
tigga212, Mar 22, 8:59am
the trans went in it a fewweeks ago thought thtat might of had something to do with it, hasnt fixed the probelm
