Reset Timing Belt Warning light
bjmh, Mar 21, 7:50am
2005 Toyota hi-ace.KDH 200V.2KD FTV 2.5 diesel. Any info resetting timing belt warning light.cheers.
tatts2, Mar 21, 7:54am
to reset the light you need to remove speedo dash assembly ,on the back of the printed curcuit there is a small screw and a hole next to it remove screw and fit to empty hole . refit assembly
incar., Mar 21, 8:21am
x1
Turn ignition on
Turn ODO/Trip display screen to ODO and turn off
While pressing trip switch turn ignition on and hold for 5 seconds
Release trip switch, press trip switch again within 5 seconds
Transfer to the T-Belt mode and follow initial setting value is displayed km 15 (0,000) kms
a.woodrow, Mar 21, 10:19am
x1
incar is on to it
bjmh, Mar 21, 11:55am
thanks people.
