how do you remove them from an allow block ? (safely ) what sort of sealant do you use on replacements ?
stickman4u,
May 23, 3:30pm
you tube is your freind
martin11,
May 24, 7:26am
You can drill holes in them and cut them carefully and then pull them out do not mark the block . Not normal to use a sealant on replacement them unless there is corrosion in the block around the seating area .
frytime,
May 24, 8:11am
Extention and hammer to knock them side ways. Pilars to pull them out. Socket to tap them in. I use shlack (sp) to seal them
mrfxit,
Jan 16, 10:11am
Yep always done them like that. It's just that last 'tap' you have to watch so you don't drop the bstard down the gallery
