Hi out there suspension experts, my BA Falcon rather noisy. It makes quite a heavy thumping type sound when going over bumps and it is like metal on metal. I have replaced rear and front sway bar links and bushes. I am picking either rear upper and lower control arms and/or blade control arm. Any thoughts out there
Oct 5, 5:43am
Check shock bushes.
casper35,
Oct 5, 7:13am
Yes check your shocks. Mine was doing the same and it was my left shock stuffed inside.
twink19,
Oct 5, 11:54am
some BA models had a rear ball joint problem
Oct 5, 11:58am
Rose joint failure is not uncommon, I've also heard of diff mount failure occurring on them too.
michael555,
Oct 5, 3:50pm
Check the bushes. Replaced mine two months ago. Cost about $270 I think
stornello,
Oct 5, 3:59pm
Top shock bush - looks ok, put your hand on it and bounce the car a bit, you'll feel the movement.
mileyfan73,
Oct 5, 6:23pm
My EFII had the same problem was worn shock.$300 a pair plus fitting.Quiet as a dead mouse now.
2pennies,
Mar 25, 5:18am
Hey guys, how can you tell if its the Rose Bushes or the Diff Bushes Any ways to test
