Old school mechanic wanted in Oamaru
kevlight, Apr 12, 7:58pm
Have a MAXI out of long term storage;car rego is on hold ,(car is UK 1500 and one owner) we want a mechanic to pump up suspension and free up brakes,and perhaps a tickle here and there to bring up to WOF standard,is there a mechanic familiar with these old cars in Oamaru; thanks KEv
robotnik, Apr 12, 8:48pm
Maybe Lance Doran Automotive. They are the Mazda service agent, but they have some older guys working there and I am sure I've seen old British cars parked out front on occasion.
https://plus.google.com/110083548129489407068/about?gl=nz&hl=en
robotnik, Apr 12, 8:50pm
Also maybe Rod Tempero.
http://rodtempero.com/
supernova2, Apr 12, 8:57pm
Biggest problem might be finding a garage which has the pump for the suspension. The rest of the work should be able to be completed by any competent mechanic.
monzaman, Apr 12, 9:11pm
I think it's called hydrolastic suspension, left and right systems and not just a tyre gauge to pump up and hoping no major leaks,clutches can also rust/stick solid to flywheel and pressure plate if sat a long time.
robotnik, Apr 12, 9:16pm
heads1st, Apr 12, 9:46pm
Try Gillies Service Centre in Ouse St, they were the agents for Austin ~ BMC etc.
strobo, Apr 13, 3:28am
GT Gillies, Austin /Morris division dosn't exist anymore,That is where Maxis were sold and serviced.Any other Automotive workshop with a hyd/pump should be able to help you.Those pumps are still about.Prob more so around Oams.There is One x Gillies Automotive engr at North Otago motors group .or maybe retired now ,he a owned Maxi 1750 his daily car. &.was the head poncho at GT Gillies Austin dept(Maurice) / Ol Tempro is of no help! or try Waimate for a pump.
biddy6, Apr 13, 6:49am
Hi Goose, Gillies would be my first call, hopefully they didnt throw there pump gear away when they moved to Ouse street.
afer_daily, Apr 13, 9:23am
i hope that you dont expect old school labour chargers ?
morrisjvan, Apr 13, 11:15am
just exactly which years do ''old school'' span ?
biddy6, Apr 13, 11:44am
Pre fuel inj?
franc123, Apr 13, 12:00pm
Its a weird non specific term used by young people who cant define it themselves. You tend to think RWD non computer controlled cars with metal bumpers but I've heard it applied to a 1988 Galant VR4 before today, which is amusing to say the least. I spose if you were born after 1990 or so it probably is.
ozz1, Apr 13, 12:42pm
go see geoff at smash palace. that old bugga will know someone to recommend.:)
mrfxit, Apr 13, 1:20pm
Probably applied to anything thats older then the person stating "old school" but they themselves only born around middle of 1980's
scuba, Apr 13, 1:35pm
i think you may find he is "unavailable" that day.
strobo, Apr 13, 2:52pm
Tempro are body builders first & formost you'll find they never wanted a pump or need or even have one ! Nothing they did involved hydralastic suspension,or at least Rods Dad was of that view from what I remember then.
supernova2, Apr 13, 4:57pm
Ye gads that expensive. Back in the day I made my own with an old landrover clutch master cylinder and a bit of kiwi knowhow.
This is the tricky bit you need
http://aamason.com/aamason_010.htm
strobo, Mar 15, 10:47pm
https://www.youtube.com/watch?v=zRXNAC_6uBc
This is the only type of pump I have ever used or seen in NZ , a change over 2 way valve will change flow to pump the height down if needed as well as pump up ,use a measuring tape from a flat ground to the bottom of the mud guards for measurement or top of the wheel to the bottom of guard equal all around the car.These pumps are still about have seen them in country garages and at auctions.
