For a Toyota 1HD FT engine? (24V SOHC, not EFI) It's high mileage, but doesn't seem to use any oil.
Synthetic? Mineral?
clark20,
Jul 11, 7:56am
The way it is today with new standards there is no real "bad" oil, it depends on how long you use it for. Synthetics will last longer and resist heat (turbos) better however minerals are still good (and stick to cam lobes better). Just don't leave changing it for too long.
Jul 11, 7:57am
diesel use a good diesel oil in winter a thinner oil would be better mineral oil.
Jul 11, 8:00am
there is bad oils if you use a dpf engine oil in a old diesel you can destroy the bearings
clark20,
Jul 11, 8:00am
One piece of advice I heard was do not use Syn if the motor uses oil, as mineral will burn off, syn will burn and leave deposits (eg on the back of valves with leaking guides) and be hard to remove in normal use. The guys here may be able to say if this is true, I haven't opened up a motor for decades.
clark20,
Jul 11, 8:01am
That's not a bad oil, that is the wrong oil
mrfxit,
Jul 11, 9:32am
Best advice I have seen evidence of about high KM engines is DON'T use synthetic oils. It cleans the engine of any hardened deposits that are possible keeping the engine running good. Seen this happen a few times over the years with perfectly running engines that the owner wanted to future proof as a birthday present.
Best to use a couple of short interval oil changes (Eg: 500kms) & carry on doing oil & filter changes at recommended stages (NOT over)
mrfxit,
Jul 11, 9:34am
If it's already showing heavy signs of sludge in the tappet cover, LEAVE IT ALONE & just run it as per norm with std oil change times
totally false but hey whatever keep spreading crap around the internet noone seems to mind
tamarillo,
Feb 23, 5:27am
If you know what oil it has been on, use that. Seriously.
