Hi,how long to change a cambelt 1995 Hilux LN85 2wd no aircon
llortmt,
Aug 25, 7:33pm
Cambelt or Cambelt kit i.e. tensioner, idler, seals etc? What about the water pump are we doing that at the same time?
budgel,
Aug 25, 8:37pm
A pair of amateurs who had never done a Hilux before took about 3.5 hrs in a home workshop. Having no aircon makes a difference.
rim12,
Aug 26, 4:21am
water pump to be done as well as a cambelt kit to fitted
bjmh,
Aug 26, 7:01am
I have a Autodata book here ,that says 1.8hrs ,but add water-pump, cam /crank seals ,a tight as crank pulley. then you discover alternator belts etc need replacing and its become the piece of string.
melonhead1,
Aug 26, 7:46am
While you're in there you might as well do the lot.
mrfxit,
Aug 26, 8:05am
Meh, anything from 1 hour to 8 hours depending on what spirits or incentive is about.
This I do know, removing the radiator speeds up the job & removes a lot of accidents.
bjmh,
Aug 26, 8:59am
agreed . radiator out,i have never been able to match those autodata times
Aug 26, 12:27pm
you have to add them up like fan belt times and cam belt times and coolant system change times and you get plenty more time. way more then you need , so you use cambelt and cooling system times and skip fanbelt times then you get about what it should take
budgel,
Aug 30, 12:31pm
You back at work Intrade?
