hi my 07 petrol triton motor continues to rev when i change gears , the revs do come down if you wait a few seconds, is this a computer problem or sensor related, thanks
brapbrap8,
Sep 17, 6:54pm
I am interested to know this too, my 2012 2.5 diesel has started doing this on up shifts since the last service too, I thought possibly it was an update or something as I swear it has less turbo lag now.
Do you know if the petrol uses an electronic throttle? I wonder if they get a bit laggy when you lift off for up shifts? That is what it feels like in mine anyway.
wind.turbine,
Sep 18, 4:50am
my 3.2 diesel does the same but only seems to do it when cold
phillip.weston,
Jun 13, 11:37am
At 8 years old now the throttle plate probably has some build up of muck around it and the idle stepper motor is at max opening adjustment. I would try clean out the throttle body and reset the base idle speed - it might help.
