I am stunned. Not that your girlfriend knows more about cars than you. But that you did not put this question to google to save some face before posting on a forum.
May 20, 3:56pm
ok poster 1 you got quite a few facts wrong , any petrol injected car has a electric fuel pump. older diesel dont have a fuelpump electric as they have a suction pump isnide the mechanical rortary pump. some have a mechanical lift pump like old carburettor pwetrol engines. Modern diesel almost all have 1 ore more in tank fuelpump to feed diesel up to the high pressure pump. one that dont are some ford and they destroy the commonrail pump if you crank em long enough dry . mercedes have a mechanical gearpump on the generation one commonrail bosch system , but mostly you can say modern cars have more then not a electric pump.
May 20, 4:00pm
Toyota runx--remove rear seat squab and you'll see the top of the fuel tank and the top of the lil electric fuel pump
pozzie-nz,
Jan 22, 5:57am
+1 Filter is built into it and is not the strainer on the bottom.
