Disc Brakes
v8_mopar, Oct 19, 1:33pm
Works good yes as far to say they do stop the mass but so loud. Why must they squeal in the dry and worse in the wet.
I have removed them and heated them on the fire to burn off oil and grime but this only helped of about 5km.
2012 Bauer Bravo 6061 series
Any ideas to stop the squeal?
clark20, Oct 19, 1:38pm
New quality pads?
v8_mopar, Oct 19, 1:46pm
back set are factory and front have just been replaced about 50km ago. Dont know how good they are or if you can get better
xs1100, Oct 19, 1:47pm
go bendix pads or the better remsa pads they are European made
socram, Oct 19, 2:35pm
Never ever had that problem, so sorry, can't help.
panicky, Oct 19, 2:39pm
Do they make them for bicycles?
panicky, Oct 19, 2:48pm
have you tired putting them on a slight angle? if possible?
macman26, Oct 19, 2:50pm
Have you tried a bit of grease on the BACK of the pad. Sometimes the squeal is the pad to piston area.
v8_mopar, Oct 19, 2:55pm
#7 and 8 They only fit one way per there shape and attach by magnet so they move back out when the pistons do. Could try the grease on back or maybe a file to the edge of the pads?
alimac1, Oct 19, 2:55pm
CRC make a disc brake anti squeal that can be sprayed on the back ov the pads, and the shims before they go in
v8_mopar, Oct 19, 3:01pm
I didnt know that alimac1, Ill have a look for it. You moved from Chch?
dublo, Oct 19, 3:22pm
My Triumph 2000's front brakes' new pads squealed - there was no space left to fit the anti-squeal shims. Finally got around to fitting the shims when the pads wore down a little and my garage expert suggested adding a little copper grease to both sides of the shims. Result: silent brakes again!
snoopy221, Oct 19, 3:27pm
End of the day tis just a harmonic vibration old skool=grease later invention is high temp silicon
martin11, Oct 20, 5:40am
Did you put the shims in the correct way round after you had them out ?
kazbanz, Oct 20, 7:01am
http://www.bauerbikes.co.nz/mountain-bikes/bravo
I would do the following.
1) clean up the disk First with brakeclean.
2) clean the pads with brakeclean then sand the face of the pads on a completely flat surface.
3)sand the leading edge of the pads at a 45 degree angle to take away the sharp leading edge.-
That should help heaps
gmphil, Jan 21, 5:10am
had this a couple of times different vehicles and as said was the shims
