70 yamaha outboard
seanlou, Feb 21, 8:02pm
hi everybody I have a 70 hp Yamaha 3 cylinder 2 stroke and it has just cracked the alloy block long ways down the block threw to water jacket what would be your guys thort on welding it in place cheers
bigracket, Feb 21, 8:39pm
Um good luck with that, i guess you can always get out and walk home?
xs1100, Feb 22, 7:22am
how many threads would you like to start on this.its not going to change anything
budgel, Feb 22, 7:49am
Advice is what you ask for when you know the answer, but wish you didnt.
nichen, Feb 22, 8:58pm
you need to find out why it cracked maybe the crank is out of balance
klrider, Feb 23, 5:56am
Welding wont fix it, duct tape is the answer. All you need to do is put some gorilla glue in the crack, run the engine for a while, let it cool, then place a good strip of duct tape over the glue. Make sure you remove all excess grease oil etc, because the tape needs to stick directly to the metal. This fix should last a good ten years, no problemo.
martin11, Feb 23, 6:01am
ABSOLUTELY RUBBISH THIS SUGGESTION THIS PERSON IS AN I___T
klrider, Feb 23, 6:19am
What! , how can you say that unless you have tried it? This is a proven method that all mechanics are taught day one at mechanic school. Everyone knows that you can gorilla glue a block back together, the duct tape is really just for looks, you can try and source something of a similar colour and you wont even notice. Once, I glued the bock of a V8 race car ten minutes before it went on to win Bathurst, granted, it was shagged afterwards, but it got it through the race. We couldn't find the right colour duct tape, but no one noticed which was a relief. Why anyone would consider welding when there is duct tape and gorilla glue at your local hardware is just beyond me.
mechnificent, Jun 3, 2:07pm
Ha. That's brilliant Kirider.
