Mixing tyre profiles
monsieurl, Oct 8, 6:26pm
Hi guys, i'm wanting to know if i can mix the profile of my tyres? ie replace two 255/35/18 with 255/40/18 on the same axle? Car is an 06 RS4.
I'm not planning on replacing the other 2 just yet as they are less than 1 year old PZero's but would prefer to go a step up in the profile. TIA
boss_hogg, Oct 8, 6:51pm
Is the car All wheel drive? I'm no expert but would think all the rolling diameters would need to be the same for the longevity of your car.
Cheers
tamarillo, Oct 8, 6:59pm
No. It's 4wd so must have same rolling diameter on all driven wheels.
monsieurl, Oct 8, 7:54pm
Thanks guys, I had that feeling. will buy some cheapies and change them all next go ;)
unclejake, Oct 8, 8:49pm
The rule of thumb with an AWD system used to be that a 5% difference in rolling diameter is OK.
An RS4 is a pretty special car
tamarillo, Oct 9, 4:59am
I think that these days the electronics get upset even if actual drive chain doesn't, which I'm told it would on Quattro.
martin11, Oct 9, 7:02am
The centre torque sensing diff would be working hard with different tyre sizes on a quattro possibly cause problems .
The following is out of my A6 Quattro workshop manual .
"On four-wheel drive vehicles tyres of the same type and tread pattern must be used. Otherwise the centre differential may be damaged. "
skin1235, Oct 9, 7:03am
DON'T
DON'T
DON'T
just one out of size ( spare ) on the rear managed to tear the front diff to bits on my AWD in 60kms
mainlander05, Oct 9, 7:09am
Yes well don't mess with Tyre sizes on Audi.
We just replaced a Tyre for an Audi was $850 because it was a run flat.have to replace with the exact Tyre they come out with as stated by Audi.
You can't and shouldn't try change things.
martin11, Oct 9, 7:10am
What model did you have do this please ?
skin1235, Mar 8, 1:37pm
wasn't audi, was full time 4wd, no center diff as they have LSD's on the front
