My son collided with a flexible road marker on the Napier/Taupo road leaving scrapings of rubber firmly stuck onto the bodywork of his car.First thought is to remove the rubber with cutting compound which could damage the paint underneath. Could someone please offer a better solution such as a solvent for the rubber streaks?
Thank you.
ignition328,
Jan 29, 8:56am
Bit of thinners used to be what I used on the speedway car.
gazzat22,
Jan 29, 9:06am
TRy petrol or turps ,.thinners could damage(dissolve)the paint.
cubasesx,
Jan 29, 10:27am
How about de-solv-it?
sqidlie,
Jan 29, 12:42pm
A great dollap of elbow grease and a damp cloth with toothpaste on it
martin11,
Jan 29, 12:53pm
Thats just a substitute for a cutting compound try petrol or turps first
nesta129,
Jan 29, 1:30pm
or if you got a drill. get a rubber wheel bit.I found that gets rid of rubber on bodywork then clean up after with turps. Check $2 shops or any Paint shops for them.
Jan 29, 4:37pm
Thinners on a rag--job done
islaybrian,
Jan 29, 5:44pm
Hey thanks everyone for your suggestions.I will try these out in the morning
annies3,
Jan 29, 5:49pm
If the rubber is thick, use a heat gun on med heat with a scraper, then polish off the remainder with solvent, otherwise just polish off with the solvent.
lookoutas,
Jan 29, 8:55pm
A road marker that leaves a rubber mark? Not discounting that it could be something different than a regular white plastic one.
monzaman,
Jan 30, 8:31pm
Kerosine easily gets non-automotive paint and tar off like a cutting compound but doesn't damage car paint,I've saved a couple of people bumper repaints.
Something like this could also work, and designed not to harm paint
tool_shop173,
Jan 30, 8:41pm
You probably need a Caramel wheel. That will do the trick nicely.
islaybrian,
Jul 15, 4:03am
Hi all thanks again for your comments. In the event I managed to remove all traces of the substance with turps so all happy now.
