2010 ford ranger flash relay
zhl, Jun 3, 10:59am
I upgrade my tails lights to led, but the turning light not working properly, I did some google, need replace the relay to led one, does anyone know where the flash relay located? Many thanks
tatts2, Jun 3, 12:17pm
intrade, Aug 4, 3:00am
well i dont know if that relay is from a ranger because our dacia 2010 has not got a flasher relay its all computer controlled and a noise in the dashboard makes the renault sound di- doo di doo . instead of a clicking relay. its to save on waight every gramm saved gives better economy and lower emissions. But dont know about a 2010 ranger unless i see a wiring diagram for it .
also change to led often makes cruise control not function as there is no load seen any more when you brake as it did with normal incondesond bulbs
