My Toyota Auris (Corolla) 1.8 cc has a blown tail light/brake light.
How to I remove and replace the bulb. I cannot get the bulb out via the boot, after removing the cover/panel. Do I have to remove the whole unit by undoing the screwed fittings I see under the cover to access the bulb?
This should normally be a simple job for the owner I suspect.
lookoutas,
Sep 20, 1:50pm
Some of those lights need to be removed. There should be a couple of screws on the inside edge, then thump the side edge of the light in a backwards motion, with the palm of your hand.
mariner26,
Sep 20, 6:47pm
Thanks for those ideas.
So, there are two possibilities?
May 30, 12:16pm
two possible bulbs-you'll see soon enough once you pull the bulb out-most likely a dual filament though
