Chev engine.
ty351, Feb 23, 8:06pm
does anyone know how to tell the difference between a 350 and 327 without pulling it apart? engine number is 3970010 if that helps.
rob_man, Feb 23, 8:14pm
Same block different crank from memory, the big journal 327s anyway. That's the last of them in 1969. The earlier ones were 283 blocks as I recall.
tamarillo, Feb 23, 8:14pm
It's 23.
rob_man, Feb 23, 8:17pm
According to this site it's either a 350 or 302 but they are the same block as a 327.
http://outintheshop.com/faq/casting/castings2.html
attitudedesignz, Feb 23, 8:19pm
'69-'79 350, 'low power' are 200 hp and 'high power' are 370hp. Also worth plucking sump as 010's are either 2 OR 4 bolt mains.
jmma, Feb 23, 8:20pm
attitudedesignz, Feb 23, 8:21pm
It WILL be a 350.
And OP if it turns out it's a 302 tell no one except me and i'll be on ya doorstep with a big bunch of foldies.
rob_man, Feb 23, 8:25pm
And this one has it as either 350 or 327. All in the stroke.
http://www.nastyz28.com/sbchevy/sblock.html
ema1, Feb 23, 8:45pm
^^Same as I found^^. 327cid (1968) 2 bolt mains only .
and also 350cid (1969-1976) was had in both 2 bolt and 4 bolt type mains.
Both used the 3970010 stamped block castings. Different internals obviously.
kevymtnz, Feb 23, 9:00pm
petermcg, Jun 1, 2:11am
Lot of those 0010 blocks only had 2 bolt crank. The 327 and 350 use the same size piston, but the gudgeon is set at a different height. because of the different stroke.
