Whistling hilux diesel
otago147, May 18, 10:38pm
Annoying whistling from engine compartment when slowly accelerating my 3.0 hilux diesel. I vaguely recall a similar problem that was solved on this forum about 2 years ago but cannot go back that far in searches. I think it was a minor repair, something to do with a banjo bolt. Anyone out there remember or know?
frytime, May 19, 4:37am
what year hilux? what engine? turbo or n/a?
reggienz, May 19, 4:52am
Sounds like the turbo.
intrade, May 19, 7:33am
post engine number under bonnet on black tag as per post 2 first
franc123, May 19, 8:18am
If its a 1KZ highly likely its coming from the check ball valve in the return line from the pump, there is a revised spring from Denso that is available from Toyota. Had this on a Prado, it sounds like a whistle coming from the dashboard, though in my case it also made the noise at idle.
frytime, May 19, 2:03pm
Agree with #5. Can be heard in the car but not under the bonet. have also had an alternator that sounded like a toast turbo On one of those
otago147, May 19, 5:24pm
Brilliant. Did a google search for "return line diesel hilux "and even got a picture of the offending part and suggestions to adjust the spring. Ten minutes later , job done, whistling gone. Thanks everybody.
franc123, Jan 24, 2:51am
Fantastic. Weird problem though ain't it?
