have a 94 surf, KNZ130 with the 1kzte 3.0 T/Diesel. Today it started to overheat going up hill, its fine on the flat (drove 60kms home on flat without any overheating). Im hoping its not the head. Im thinking radiator block as they can if neglected (I havent had it long) So thinking a new radiator (or getting mine recond) and replacing therostat and new coolant etc should fix. Thoughts!
r15,
Jan 8, 6:58pm
Its likely your radiator is choked up. It will need to be removed, disassembled and cleaned out by a professional.
It is also highly likely your viscous fan hub is failing. These are adjustable if.you dis assemble them.Over time the bi metallic spring that controks the amount of fan lock up.
If you can't hear your fan roaring with the windows up then its not working properly.
for more info join up and search google for the australian surf forum
snj11,
Jan 8, 7:05pm
thanks, thats what i was thinking, hoping it hasnt done any damage, i know these hate getting hot
r15,
Jan 8, 8:52pm
i just re read my post, it makes no sense.
over time the bi metal spring loses effectiveness, this can be adjusted out.without adjustment most surf's fans never operate fully
Jan 8, 8:57pm
How exactly do you adjust them! Can they be tightened up!
muzz67,
Jan 9, 5:33am
Auto! Do the trans cooler pipes run into the bottom rad tank!The pipes block a lot of the rad outlet, so fit an aftermarket trans cooler and remove the pipes from inside the bottom tank while you're getting the rad serviced.
snj11,
Jan 9, 6:21am
Hi, no this is a manual
the_don_61,
Jan 9, 6:31am
94 toyota desail. .blocked rad.fautly worn out water pump.
allways do water pump with a cam belt.
r15,
Sep 1, 3:08am
adjustable if you take the clutch apart, there is adjustment slots in there.
what you are adjusting is at what point of the bi metallic spring's internal rotation the fan kicks in.as time goes on the spring moves less. simple solution is adjust it so that the fan comes on sooner.
ideally a brand new part would be fitted, but apparently these are often adjusted too hot anyway so would also need adjustment / checking.
