Michigan 35 loader, brakes. or lack thereof
xacoon, May 7, 6:17pm
Anyone changed the brake cylinders on a 35aws and can give me any pointers? seems to be a hard loader to find much useful info on.
serf407, May 8, 6:36am
There are other places around the net to ask for the older industrial gear information, where the retired old time mechainics hang out.
http://tinyurl.com/mx9jbc5 There are reproductions of the original workshop manuals
The online places sometimes have the original old workshop manuals.
smallwoods, May 8, 6:46am
Been a long time since I drove one of these. My first rubber tyred loader. I was 13/14. Great in the bush stacking posts. Good luck
answer, 40 years ago.
xacoon, May 8, 6:00pm
I bought this one for tree work funnily enough, save beating up the main tractor too much. would like to find a grapple for it but doesn't seem to be a lot of Michigan stuff about.
Was hoping there were some of the retired old time mechanics hanging out in here. Ah well surely they can't be too hard to do. ?
cagivachick1, May 8, 6:35pm
here is a tired mechanic called zeph
horsygirl, May 9, 10:59am
Throw the vacuum pump away and fit a compressor and Airpac off Ford D series truck. This will give you air over hydraulic brakes which are far superior.
bjmh, May 9, 12:40pm
what cylinders are you replacing,the master cylinder is fairly basic. wheel cylinders were a bit tricky. cause you have to remove the hub to get to them.
xacoon, Feb 6, 3:03am
Wheel cylinders. Master cylinder is out at the moment, fairly basic is an understatement haha took longer to find the right spanner than to pull it out.
