94 Courier 4wd farm truck, (hour from town, not reg'd. ) clutch works fine if pedal used for short time, but if clutch used for longer period then becomes less effective to a point where it creeps forward with pedal all the way down. Fluid level doesn't seem to be dropping. Have never fiddled with hydraulic clutch before,, should I start at the master or slave? Figured I'd remove and take to specialists in town. Cheers.
toyboy3,
Jul 21, 7:40pm
If the fluid is not disappearing it is the master cylinder cups bypassing
muzz67,
Jul 21, 7:43pm
Thanks,, hopefully wont have to grovel around in the dirt then.
mecanix,
Jul 21, 7:51pm
Do them both it will save you having to do the slave next week.
Jul 21, 7:57pm
also check under dust cap of slave for fluid if the cilinder is outside the box. if its wet replace it if its dry it most probaby is what poster 2 stated.
Jul 21, 7:58pm
Muzz--I agree with mecanix. Replace the slave same time as you sort the master. Logic says the seals in both are exactly the same age and been through as many cycles so if one is bypassing the other can't be far off leaking.
Jul 21, 7:59pm
yea if its cheap enough. and OP remember clutch fluid is the same as brake fluid and brake fluid should be exchanged every 24 month as best practice.
flack88,
Jul 21, 8:28pm
Yes how many people do that intrade?!
elect70,
Jul 22, 3:10am
^ i reckon its a have to sell more brake fluid & make work for mechs . much same as cooalnt every 2 years , it doesnt degrade provided you use same for top ups . .
scuba,
Jul 22, 4:59am
then you reckon wrong.
gph1961,
Nov 17, 9:18pm
2nd that
