The drivers side window has become very hard to get to go either up or down unless assisted by manually pushing/pulling it.Seems worst in the AM, sounds silly but wondering if moisture has anything to do with it. Any ideas/advice appreciated. TIA.
snoopy221,
Aug 14, 6:15am
spray can silicone lube on all accessible rubber where glass runs available from supercheap repco etc.
maclad,
Aug 14, 6:24am
Thank you snoopy will try that
Aug 14, 9:01pm
NOOOO--don't do that maclad. -well not at first anyways. if You use hot soapy water and a toothbrush you will be able to scrub into all the rubber tracks for the window and the edges of the windows. They get very grubby/Full of gunge.That might be all it takes. if not they try the silicone trick--if not then you need a new window motor.
maclad,
Aug 15, 2:34am
Would not the motor, if faulty, affect all the windows. All the rest work fine. Thanks for the advice.
curlcrown,
Aug 15, 7:01am
Graphite powder.
a.woodrow,
Aug 15, 7:12am
No each window has its own motor
Aug 15, 7:57pm
definitely not -4 windows 4 motors
Oct 27, 2:55am
sorry snoops--I just prefer to clean the gunge out first before adding more gunge.
