Can someone identify this engine location please
budgel, Sep 29, 2:21am
If you had a loose bolt, then it may be the gasket for the waterpump.
poppy62, Sep 29, 2:55am
It's stuffed! typical unreliable Jap vehicle. It'll cost an arm and a leg in parts and to fix. I thought the "Large Nut" was a reference to the owner and I was about to concur. It's also probably the only old girl you'll ever get hot!
tamarillo, Sep 29, 3:04am
Are we allowed to fight like with like? Thought Unrequested car zone bashing was only Against our euro cars? Go Poppy!
frank1, Sep 29, 3:21am
Suggest you pressure test the cooling system via radiator
poppy62, Sep 29, 3:31am
Hi mate! I can only assume his Keyboard batteries are flat. Or he's checking the listings for a VW (VAG) Amarok.
sr2, Sep 29, 3:39am
I miss Jazz.
exwesty, Sep 29, 3:59am
But is your aim getting any better?
poppy62, Sep 29, 5:51am
It's a bit hard to determine whether it's a leak from the water pump or something above it. Have you checked the hose (top rad hose) for a split/hole. Or the thermostat housing. I'd hazard a guess and say that the water pump gasket (cheap Rice paper)) is the suspect. If as you say a bolt was loose, it may pay to tweak it up and see if the leak stops, before you start pulling things apart. Sounds expensive! LOL
poppy62, Sep 29, 5:54am
Yes! he's now into Rock.
shakespeare6, Sep 29, 6:04am
That looks like one of the typical leaks those get. Just above the leak is the horizontal flat with vertical bolt which is part of the front cover there is coolant and an o ring in there which like to leak . The other is the thermostat housing where it runs down the back of the housing and then along the water pump. In your picture on the right of the pump there is some faint green on the water pump this is where it dries down on.
Owned a few of these old girls over the years and they all leak in the same spot.
strobo, Sep 29, 8:19am
If you go back to frank1 post #5 .If you can't sight it you can't call it! Put pressure into the system (motor cold) get it flowing and put an air gun into the flow to identify which demarcation lines it is leaking from .then from that determine the part or parts in question.
marte, Nov 14, 4:12am
Mals69. buggered waterpump vanes if they are plastic.
