Why are the front tyres on my van wearing on both the inside and outside shoulders? Similar wear pattern to "under inflation" but the pressure is always kept at around 55psi. Current front r/h tyre is almost showing its chords on the shoulders but has nearly 5mm tread through the centre 2/3rds. Tyre has done approx 30,000km. Van is a 2016 iLoad and I've had it since new so no accidents. It has done 65,000km and I get a wheel alignment approx once a year with every service. The tyres are 8 ply commercial rated and arent cheap so I would like to get to the bottom of this. Cheers Stevo
Jan 12, 4:19am
What is the brand/model of tyre fitted, has it always done it even before the current tyres are fitted, how often are they being rotated and can you post a shot of your last alignment printout?
OK I would be rotating those front to rear every 7500km or thereabouts, it's obviously a little too late to start doing it now on those tyres. It looks like it runs quite a bit of caster ex factory which makes rotation even more important, it's a little hard to describe in words but running that much negative caster has the effect of the tyre tipping further over on its shoulders when it's being steered. While it's not extreme I would also not be happy with the amount of negative camber in that LF wheel, that needs investigating.
toyboy3,
Jan 12, 4:58am
Tell the driver to stop chowing down on the pies 🥧 there’s too much weight on the right front wheel
stevo2,
Jan 12, 4:58am
Thanks franc. Its going in for another tyre and another wheel alignment tomorrow. Lets see if we can get it sorted. Cheers Stevo
stevo2,
Jan 12, 5:01am
I'm the only driver (and you're probably not wrong lol)
Jan 12, 5:05am
Edge wear can be more of a problem on cheap car tyres on heavyish vehicles because of more than acceptable amounts of sidewall flex but that's obviously not an issue with good quality 8 plys running that sort of pressure.
mechnificent,
Jan 12, 5:06am
Do you corner hard ?
serf407,
Jan 12, 5:07am
Where are the Dunlop tyres made?
stevo2,
Jan 12, 5:19am
Interestingly, the Dunlops are made in Thailand, the Hankooks are from China.
mrcat1,
Jan 12, 5:24am
Hey, Is 55 psi on the tyre placard? Are both the front and rear at the exact pressures as per the placard on the van? You need to have them rotated every service, the rears will be wearing fine in the centres, that's why you need to even wear with the fronts. Have you thought of going to the likes of Cooper Tires, I get real good wear out of them in my little nana car.
mrcat1,
Jan 12, 5:25am
Do you know where barge poles are made?
mechnificent,
Jan 12, 5:26am
Yeah well that would do it Stevo. Try cornering gentler and without braking at the same time.
stevo2,
Jan 12, 5:27am
Oh mate, you're no fun lol.
Jan 12, 5:32am
ok underinflation or the tyre can tilt on its axis worn ball joint. or $hitty tire
mechnificent,
Jan 12, 5:40am
Ha. Sorry about that. Try to corner gentler for six months and see if it makes a difference. I used to wear the outer and inners by cornering hard. now I don't and don't get the problem.
stevo2,
Jan 12, 5:53am
Hey Mrcat, tyre placard says 42psi front and 51psi rear. I have been advised by 2 separate tyre shops to run 55 front and 60psi in the rears because I always carry around 800kg (including my fat arse). Coopers dont do a 215/70x16 with a load rating of 108/106T Will get tyres rotated tomorrow. Back to work on Wednesday :(
Tyre has done 30k then i would not be all that concerned. If suspension or ball joints are worn then it will only get worse so will need attention to fix, but at 30,000km i would be happy to replace.
tweake,
Jan 12, 6:31am
whats the max pressure etc written on the sidewall?
Jan 12, 6:34am
max pressure on sidewall is the pressure they can take till they explode and not what you should fill em with. 42 psi would be what to fill the jinyu
mrcat1,
Jan 12, 6:56am
Interesting you say this, I don't know if you remember my black 550 Nissan Navara I used to hurtle around the countryside in, it was shod with Coopers. Now I used to carry similar weight in the back all the time, and the shops said the same things, heaps of pressure and they used to wear both sides of the front tyres and it used to scream worse than a banshee coming up the Matamata side of the Kaimais with a bit of steam around those corners. It used to get a wheel alignment every 20,000kms but no rotation. One day I had enough of chewing out tyres and I took the tyre pressures back to the placard psi recommendation and what do you know, that was the end of the banshee, and chewing out tyres, and started rotating tyres every service, then instead of getting 20,000km out of a front set of Coopers, I'd get 50,000km out of all four. And I'd still do Kati to Wanganui in 3 1/2 hrs thru the Paraparas in the pouring rain and it wouldn't even twitch. My black little nana car now is on Coopers, its pressures are 70psi front, should be 75psi, 80psi on the rear but only at 75psi and rotated every service, has no wear issues, never been aligned, and I get 50,000km out of those Coopers and it weighs 4.4 tonne. I bought a expensive Michelin tyre gauge to check them with as it has pressure sensors on the wheels and if the pressure get to far out it starts having a fit, I always check the pressures cold after its been in for a service and rotated as they can be all over the place as the guys don't really care as they not paying for its tyres.
m16d,
Jan 12, 6:56am
Obviously a driver problem. you probably drive with the gas pedal on the floor or completely off. nothing in between. and a left foot braker too.
tweake,
Jan 12, 7:04am
not really. you can run them at that pressure up to the weight specified. i use it as a guide to what to set pressures at because different tires can have completely different requirements.
