2008 Nissan Caravan Van Engine
vijay19, Feb 2, 4:28am
When van engine is cold when starting the ignition, you can hear a rattling sound from the front of the engine. And when the van engine warms up the rattling sound quietens down. Could someone please advise me what the problem could be?
cabrio1, Feb 2, 5:51am
Pre ignition, generally caused by a bad piston return spring.
Otherwise is anything obviously loose at the front of the engine?
kingfisher21, Feb 2, 5:58am
lol WTF
tweake, Feb 2, 6:01am
what engine does it have?
intrade, Feb 2, 6:02am
the question is what is it petrol diesel and a better description then a sound.
cabrio1, Feb 2, 6:23am
Valve bounce, a sure sign of pre ignition.
Replace the piston return spring.
Otherwise could be harmonic balancer, out of harmony.
Mostly a Nissan problem.
msigg, Feb 2, 6:32am
Timing chain rattle. Have you done any servicing?.
franc123, Feb 2, 7:35am
Probably a worn chain caused by poor servicing/poor oil flow to the tensioner which could be the result of all sorts of possible problems including partly blocked sump pickups or wrongly made oil filters etc.
mrcat1, Feb 2, 8:35am
WTF, valve bounce is usually a result of to many big revs.
And if the harmonic balancer is out of balance, it becomes a demonic balancer, which is totally out of harmony with the rest of the world.
gph1961, Feb 2, 8:50am
urine extraction from a ragtop
mrfxit, Feb 2, 8:53am
LOL, mmmmmmm could be a bit slippery with all that liquid manure on the boards.
I smell trouble
mrfxit, Feb 2, 8:55am
Common noise would be timing chain?
Is this a TD27 or QD32 or something else
monaro17, Feb 2, 9:27am
I’m not sure they were still using the TD or QD that late? And if I’m not mistaken, they are cam gears anyway. No chain
If its a diesel I would pick it’d be a ZD30
monaro17, Feb 2, 9:29am
Haha.
Bless, the thought was there but what isn’t there is knowledge of how an engine works.
franc123, Feb 2, 9:37am
QR, KA or ZD engines in those. TD and QD were no longer used by that stage.
muppet_slayer, Feb 2, 9:40am
2sheddies, Feb 2, 9:43am
Fill up the blinker fluid reservoir and tell us if the noise disappears.
kingfisher21, Feb 2, 10:13am
lol, yea I seen that one, its bloody well done, another youtube channel, Garage54 actually did it.
https://www.youtube.com/watch?v=dlQn7-LsLww
muppet_slayer, Feb 2, 10:29am
I doubt they actually did it because there would be no room for the compressed spring at TDC, it would be smashed into the head. Also it would foul on the valve heads and it would make a racket if they did get it going.
mrfxit, Sep 19, 5:48pm
LMAO, arrhhhh welll yea.
To those of us that have rebuilt engines, it's pretty obvious.
Love the printed box's for the springs
It's in the same class as Lucas Replacement Smoke
