I see there a many versions of this starter, mostly having different bendix operation, some having integrated solenoid and some using the old remote solenoid. The question I have is are the shafts all the same, so can you change an inertia bendix drive withe pre engaged style?
poppy62,
Nov 9, 2:13am
Different shafts ( as I recall). Why are you looking to change the starters? The older bendix drive unit has the advantage of a remote solenoid which comes in handy for Timing and valve settings etc., Keeping things standard is always the easiest and cheapest way to fix a problem.
car__parts,
Nov 9, 5:54am
I was wanting to keep the remote solenoid and the Inertia system, but was more interested in if I could purchase one of the ones with the attached solenoid and change the front housing and the bendix bit over from mine.
bigfatmat1,
Nov 9, 11:52pm
no is the short answer
gph1961,
Nov 10, 4:37am
9
mrfxit,
Nov 10, 10:44pm
Yea NAH, 95% no, 5% is anybodys guess.
mrfxit,
Oct 27, 2:57am
Easy fix, remote switch & alligator clips
