Where did it seem like the noise was coming from? You may have to get someone in the back to catch it in the act while someone else drives it. Depending on what sort of rear suspension it has , loose nuts might need rescrewing tight again or a big bolt could need lubing.
lookoutas,
Sep 2, 5:58am
If it's a red one, you're stuffed.
bigfatmat1,
Nov 27, 12:02pm
You could try and lube the steering stops
