What oil do I use.?
m16d, Jun 24, 10:03pm
What grade of oil should I use in the damper on a Trojan coupling.
franc123, Jun 24, 10:41pm
It states on the instruction sheet with the overhaul kit from Trojan what the oil is, Castrol Hyspin seems to ring a bell, it was something weird that nobody has ever heard of, why its not included with the seal kit is anyones guess. Ive used 15w/40 engine oil in mine without problems simply because I had some already, it seemed similar in thickness to the original oil. Possibly a universal agricultural hydraulic oil would also do.
intrade, Jun 24, 11:17pm
only danger is if its got seals swelling with motor oil: i would ring trojan your self and ask and also try google if the answer on the phone matches ghoogle then your probably save to have the correct information.
m16d, Jul 21, 7:17pm
OK. I've stuck some 5/40 in and we'll see what happens.
The only seal is an O ring.
