Definitely not oil. New drive, been down approx 6 weeks.
nice_lady,
Nov 8, 3:16am
Brake dust ? Really ? If it's ground into the surface of the concrete then you're probably not going to be able to remove it without using say a waterblaster and that's NOT recommended on concrete as it'll literally blast away some of the concrete surface !
kassie48,
Nov 8, 3:53am
No idea re dust?
Nov 8, 4:03am
well logic would tell you brake dust would only really show up like in your description if someone whipped a brake drum off and washed the dust with brake cleaner on to the concrete. My brain cells asked me if You was talking rust stains
cjohnw,
Nov 8, 4:05am
This stuff works well getting it off the wheels. Can’t say I have tried it on a concrete drive but should not stain.
What is the driveway made of? -Im thinking good old fashioned hot soapy water a scrubbing brush and soap
marte,
Nov 8, 1:37pm
I expect that brake dust is a mix of the pad material & the disc/drum material & so it will be made up of a lot of fine rust particals.
CLR product, concrete cleaner or evapo-rust from Supercheap auto
pauldw,
Oct 27, 5:56pm
If it's black marks it's probably just rubber off the tyres.
