Hi, A series one Prius, 2003. An orange ABS light has come on constantly today while driving. Does this signify a problem for the garage to sort? Thanks,
There are many reasons for the ABS light to appear. Some are a quick & easy cheap fix, others are more serious and expensive. The only way to know is to get it scanned, have the light reset and see if it comes back on. If not, all good. If it does, then re-scan for codes and go from there. If you don't have a Toyota scanning tool then it's off to a good auto shop.
dutchess46,
Feb 12, 6:16am
Thank you all.
Sep 15, 8:42am
good news is that this specific fault has little or nothing to do with it being a prius. Most likely issue is a sensor fault. But it needs sorting
