Late model Mitzi Canter. Ignition turned off Indicators all work perfectly via hazard and individual use. with the ignition turned on but vehicle not started as well as vehicle running right front indicator stops working. This is all the time not intermittent. I've gone through the obvious stuff. Bulb changed left to right then replaced with a new bulb . Bulb holder checked. Bulb holder unplugged from loom and trouble light same amps plugged in. --All giving the exact same result. Everything else works perfectly. so no warning tones anywhere. Scratching my head with this one
gpg58,
Nov 17, 1:41am
has any aftermarket accessories been added to it, like reversing cameras etc? just wondering if someone has connected something where it should not be, as some lighting is live to bulb, and the switch earths the other side, causing weird issues if that live feed is tapped into. Possibly unlikely, but have you checked all fuses, just in case. Unlike our old bombs, weird interactions can happen when one is blown, and circuit back feed from something else with all this modern crap fitted.
Nov 17, 2:44am
ok i think you have a ground problem. Better explaind in this example. complaint car cuts out at red lights with brake applied. Fuelpump stops working when the lightbulb turns on and uses the ground the pump used Thru the light bulb. and now the light uses the ground the poor ground the pump has is shutting it down as it can no longer use the ground it borrowed.
I would like to know whats on the same ground and where the indicators ground is and its condition. as i think your indicator borrows its ground from something else .
mrfxit,
Nov 17, 2:44am
Clearly something within the ign powered system Questions.
All the same original bulb holders Only factory lights fitted including park/head/ high/low beam (width lights?) Replacement high level brake light Original indicator control can Original indicator stalk
No odd bits of melted/ distorted cable wrapping
Nov 17, 2:46am
My bad-I tried to put all detail in. This is a totally stock truck so no accessories at all. Its even only got the traffic radio. Yes I've gone through and checked all the fuses although Ive never seen individual indicator light fuses before. (as in individual corners not sides)
bigfatmat1,
Nov 17, 2:58am
indicator switch fault. Or hazard light switch fault. Possibly even a flasher unit fault.
Nov 17, 2:59am
hazards work normally with ignition off. only right front 'fails" with ignition on/hazards on.
bigfatmat1,
Nov 17, 3:01am
sorry didn't see only right front. Connection issue. Does vehicle have turning lamps?
mrfxit,
Nov 17, 3:10am
Arrh yes good thought The tell tale might be one not working/ shorted?
sw20,
Nov 17, 3:18am
My old Blade Master the previous owner had fitted a second set of "tail lights" in the place of the lower reflector lenses. They had just wired them into the 12v of the original tail light wiring. Eventually one of the tail lights would turn off when you started the car. Removed the wiring for the extra tail lights but it didn't fix it. Had to replace the tail light as they were a sealed unit.
Nov 17, 4:27am
No other lamps-ie no auxillary lamps of any sort. so four indicator bulbs in total. -I THOUGHT I'd eliminated switch /solenoid fault because indicators / hazards work normally with ignition off just not with ignition on. -ohh and this is not an inherited from Japan issue but one that has appeared after about 100km in nz
bwg11,
Nov 17, 4:28am
Is it late enough model to a can-bus system? I know the late Outlanders and Lancers are "can-bus" and really need specialist diagnosis and are a whole new ballgame for us old buggers.
bigfatmat1,
Nov 17, 6:27am
Providing it has no factory corner lamps fitted then the front and rear indicator will be of a common wire. So you need to work backwards with a test light from the lamp that isn't going when the fault is occurring.
trade4us2,
Nov 17, 6:47am
My car, and probably most modern vehicles, now control all accessories via a computer. Elsewhere there are dozens of relays, and the computer controls all the relays. If the computer earth is bad, as more accessories are turned on, the computer may lose power and reboot several times a second. Turn on the headlights and indicators and wriggle the wiring around the computer. If everything goes haywire, solder up the earth properly or add a decent wire. First, find the body computer!
redhead18,
Nov 17, 8:52am
AYE?
Just how many vehicles do the indicators work WITHOUT the ignition turned on?
mmm K.I.S.S.
Nov 17, 10:26pm
Looks like YOU learned something today. Canter trucks the indicators work with the power off.
gazzat22,
Nov 18, 1:40am
So do most cars including a DE demio.I had a car some time ago with 2 flasher units one for indicators and one for Hazards.
strobo,
Nov 18, 2:35am
also check type of bulb they use some indicator bulbs have dual filaments and one live pole,been caught out on that a few times.both single and dual filaments use same offset pins ,easy to confuse.Its the way mitsi wire stuff.
strobo,
Nov 18, 2:55am
Other than that the indicator electronic control unit MK387291 for mitsubishi canter fuso 3C13 SWB 2005-2011 Indicator relay ,check with model etc.Ive replaced a few before on canters with so called bizzare problems and with success.probably this one >M896426-0665003391-25.6v 85c/m .Turn signal>2.5w x3 +5w=1.8w Hazard signal >25w max 6 bulbs!
shakespeare6,
Nov 18, 3:16am
Last Mitsi canter I played with which was 2012 was canbus with a SAM for lighting . Was no flasher units etc all that was done in the SAM. You would need to confirm that first if it is a late model as you say- might point to a issue.
From the owners manual a fuso 2015 with SAM system so you will need to establish if there is a warning on the dash for SAM with key on position for check lights ! 6-273.If the amber SAM warning light shows! Turn the starter switch back to “ON”. If the indi-cation goes out, there are no problems. If the warning remains displayed, contact your near-est authorized dealer immediately.•Amber warningThe amber SAM warning is displayed when a failure(of a type that requires inspection of exterior lamps)occurs in the electric control system of the SAM.If this warning appears while driving, stop the vehicle in a safe place and do the following:1. Firmly apply the parking brake and move thegearshift lever to “P”.2. Turn the starter switch to “LOCK”.3. Check the exterior lamps for abnormalities.Replace a blown lamp if any. P. 13-184. Turn the starter switch back to “ON”.5. Switch on the replaced lamp. If the warning goes out, there is no remaining problem with theSAM.6. If the warning remains displayed, contact anauthorized dealer as soon as possible. (If 2014 model has not SAM ,back to individual units and basics earths,etc). 2.6SAM warningNOTE:SAM, which stands for Signal Detection and Actua-tion Module, is a module that integrates the controland power distribution functions for the electric equipment of the cab and truck body Red warning The red SAM warning is displayed when a failure occurs in the electric control system of the SAM.If this warning appears while driving, stop the vehi-cle in a safe place. if it's CANBUS system there will be an indicator light on dash panel for this ,in check light position with key on
Nov 18, 8:23pm
Strobo--holey cow dude. When the vehicle first arrived a couple of months back the SAM was displaying. I changed a dual filament taillight bulb and it went out. You think this could be related?
redhead18,
Nov 18, 10:10pm
Always happy to be learning Kaz. The **moot point** was this ain't no mk3 cortina where you could leave either side side lights on via the indicator switch. with key out. And a new flasher unit would be my first call-as when the ignition is on it appears to be the bug bear head scratcher
