Toyota auto trans fault.
saturn51, Jun 4, 12:07am
1997 Tercel,1300cc,auto. Intermittent drive fault when motor hot or cold.Motor revs ok,car just sits there and barely moves forward or back.Similar to "limp" mode or a badly slipping clutch on a manual.
Placing car in 1,2,D or R makes no difference and there is no bump/jerk when selecting a gear.Fluid is clean,no nasty smell and full.
Drive down the road,engine revving but slow pick up,and it may suddenly sort itself out or if you leave it and return and it`s perfect for a week or two.Your thoughts would be appreciated.TIA.
modie61, Jun 4, 12:09am
That cant be true,a Toyota with an auto problem,wait for jazz he will sort it for you.
littlebob7, Jun 4, 12:15am
check the auto trans oillevelwith the engine running--- I will bet it is low
saturn51, Jun 4, 12:18am
Level spot on,hot and running.
saturn51, Jun 4, 12:19am
Will I have to fit a Fiat box to it though!
doriandarby, Jun 4, 12:34am
No, a VW DSG gearbox.I hear they are reliable.
