How many kw does a 1800cc put out compared to one that is dohc!
Oct 3, 6:12pm
An 1800cc SOHC vs DOHC! Better also state what model/year Galant before you get laughed at.
brendoooo,
Oct 3, 6:16pm
Sorry mean how many kw does a 1800cc sohc have compared to a 1800cc dohc it a 1990 galant glx
grangies,
Oct 3, 6:22pm
Both will be bugger all.
WIkipedia or Google will be able to tell you with a bit of searching. info. The engine model numbers are needed for more precise kw
mrfxit,
Oct 3, 8:55pm
If both are basic models of the same age then guessing about 10bhp difference Peak hp & torque will be at slightly different places
doug207,
Oct 4, 9:44am
88kw for the injected SOHC, 81kw for a carb'd one and supposedly 103kw for the DOHC. They're all pretty uninspiring motors though
mrfxit,
Oct 4, 12:11pm
Still tho . 81kw to 103kw is a fairly good jump + non turbo
turbomofo,
Oct 4, 12:32pm
103 kw at the flywheel, it whittles away pretty quickly after that. i went from the 4g63 SOHC to the 4g63 DOHC it wasn't much different, pulled better on the butt dyno at 100 but that's about it
