Hi. I was cranking it up to about 9000 rpm tonight and it just died. No light, ignition, horn , indicators etc. Nothing ! I checked main 30 amp fuse under side cover and the smaller fuses under the instrument panel. but they are all fine.
Any advice please ? Mike
countrypete,
Jan 26, 7:54pm
Get a Suzuki! (Or check the kill switch)
mekongmike,
Jan 26, 7:55pm
Thanks Pete. obviously a Suzuki fan.
countrypete,
Jan 26, 7:59pm
Also a fan of kill switches.
Jan 26, 7:59pm
9000rpm--and wheres redline on a rolladoor? --if you've lost everything check for busted connections.
mekongmike,
Jan 26, 8:10pm
kazbanz. redline starts at 9000. yeah, possible a broken wire . I'm not sure where to start really. I thought it would be a fuse but no.
muzz67,
Jan 27, 4:54am
I had an XR600 which would loose all the lights as soon as I went over 90kmh. Was the regulator getting hot, moved it to get more airflow and was sorted. Not sure about your situation tho.
twincam1,
Jan 27, 4:59am
Try contact cleaner in ignition switch.
bigfatmat1,
Jan 27, 6:40am
Make sure the is voltage in the battery
m16d,
Jan 27, 8:30am
Yer battery terminal probably broke off with the vibration.
mekongmike,
Jan 28, 10:53am
Broken wire under fuel tank. all sorted.
twincam1,
Jul 20, 4:51am
Bloody hot weather, my rectifier popped its clogs today on the Honda.
