Charging battery on car with computer / C.P.U !
ignoramus1, Sep 16, 7:44am
ok im no electronics expert the car is 4 liter Fairmontwith a computer /cpu unit . I am wondering if it is dangerous to the health of the computer to charge the battery WITHOUT disconecting it ( removeing positive terminal) just using a handyman type 3 amp charger overnight.
Logic would suggest just clip the charger on without removing the leads on battery , but the reason i ask is that chargers dont realy give a "clean" power supply (kind of a truncated sine wave rater than a flat clean DC.)
MY worry is that the "pulsing" of the charger could damage the CPU
any comments!.thanks
sgrants, Sep 16, 7:54am
It is advisable to disconnect the battery when charging!
ignoramus1, Sep 16, 8:08am
any particular reason why it is advisable! .
sgrants, Sep 16, 8:31am
spiking damage to electronics!
pup2, Sep 16, 8:52am
This is a good question. Would like to hear peoples opinion on this. We disconnect the battery when charging the battery in the car, but we also sell maintenance chargers that work at 1500mA and lower, with the sole purpose to maintain the battery when the vehicle doesn't get used very often. Customers fit these to their new cars (eg-ford boss), 4wd's etc. Battery is not disconnected when the charger is connected to the battery. Hasn't damaged any modules.
andrea_w, Sep 16, 8:52am
Also. remove the Negative terminal, not the Positive
crzyhrse, Sep 16, 8:52am
I've never bothered and never had any problem. I went through a spate of leaving the boot ajar and deep discharging the battery about 4 times in a couple of months and just charged it still connected. Same car too.
elect70, Sep 16, 10:08am
Hardly wise surely,srereo lose itsanti theft code, ECU , & other things with memories canlose itsrunning settings . . I leave my BMW on trickle charger permanantlyas its only a weekend warriorNever had problem . Even charged it on hi charge20 ampswhen it nearly went flatafter boot light switch stuck on.
ignoramus1, Sep 16, 10:57am
i would have thought surely that if the key was off teh computer would be protected whist charging!
pup2, Sep 16, 10:59am
computer has a full time power supply
bigfatmat1, Sep 16, 1:01pm
waste of time I never disconnect batteries while charging them NEVER I say
phillip.weston, Sep 16, 1:09pm
as above I've never disconnected the battery when charging them. The battery acts as a voltage stabiliser/buffer. I've even run the car electrics straight off a battery charger with no battery connected just fine.
richardmayes, Sep 16, 1:25pm
Would a home trickle battery charger hit the electrical system of the car with (more power / as much power / less power) than the car's own alternator does during normal running!
ignoramus1, Sep 17, 8:36am
no it wouldnt .its only 3 amps .the point is that the cars power supply is fully regulated to give "pure dc" to the battery. Whith a charger it ISNT a "clean dc" power supply see original post .
I dont know the electrical terms but there is a difrence between what you get off a battery charger and cars supply.
OK now i have some unbiased opinions the reason I ask is becuase the car blew the computer THE DAY AFTER i fully charged the battery overnight.big coincidence or did the chargeing (without disconecting battery) stuff it.if its a coincidence its a big one!
sr2, Sep 17, 2:28pm
Where on earth did that idea come from! I'd suggest you put a scope on an alternator and a battery charger, you might be suprised!
johnf_456, Sep 17, 2:31pm
As someone in the trade I never disconnect batterys, for the sake of loosing stereo security codes and having to retune radios why bother.
dent, Sep 17, 2:43pm
probably the main thing is not to disconnect the battery terminals but make sure when connecting and disconnecting the charge that its switched off. This will reduce the chances of spikes.
sr2, Sep 17, 2:50pm
yes, good practice.
bigfatmat1, Sep 17, 5:19pm
Be a coincindence. Who diagnosed a blowen computer on the car and has this been fixed yet, or is this the assumed problem.
ignoramus1, Sep 19, 7:13am
Just going by what those who know more about it than me say. But I do know that running a 12volt horn off a battery charger and off a battery (motorbike horns) makes a huige diffrence to the sound (not just the volume)
ignoramus1, Sep 19, 7:16am
not assumed problem, comp was blown, diagnosed by auto electrician, its fixed , just trying to get to the bottom of likley casues of issue .looks like battery charger may have contributed if not caused.
bigfatmat1, Sep 19, 12:35pm
It would be bad luck. power supplies in a ecu are diode protected and regulated for this reason Also about the ac ripple mentioned above this would be minimal .5v peak to peak and only on a crap charger roughly what you would see on a alt some chargers will rise to above 16v but a ecu can handle this voltage
loonee-dial-111, Sep 20, 9:08pm
Some fancy chargers put spikes on the battery to desulfate, I would read the manual on those before connecting. But in general if it's a cheap basic charger I wouldn't be concerned. I have charged many cars with the battery in place.
bae13, Nov 13, 3:07am
this is true, i have seen latemodel bmws/vws overcharging at 22 volts and had no other issues. like has been said the output from an alternator is far from DC its a rectified ac output to replicate a dc but it still has peaks of ac in there.
out of interest has the OP mentioned what vehicle it was!
and by blowen ecu can you be more specific, like did the car have a miss, did it not start, has the repairer mentioned if it was missing spark, fuel etc
