Mitsubishi Libero GT problems
tekaholics, Sep 19, 7:50am
This car is a good car, BUT.it has a knocking noise. Its does it everytime I turn, go over bumps and sometimes brake. A mate of mine said it may be the tire rods or balljoints. Any suggestions! And a price in mind! Thank you.
morrisman1, Sep 19, 8:12am
I would be looking at all the rubber suspension bushes and ball joints. Shouldnt be overly expensive to fix
srrolla76, Sep 19, 2:40pm
check ur wheelnuts are tight. mine was doing the same thing and turns out i had loose wheel nuts.
xraps, Nov 10, 3:15am
A few years ago i worked on a libero with a mystery knock, turned out to be the front sway bar bushes. The nolathane replacements are cheap enough (less than $20 iirc) but i seem to remember fitting them was a pain.
