My car just passed a WOF with one , the guy i brought it off also put a new WOF on the car with it on. Are they much like a BOV , just make a noise but don't really help the car performance.!
Nov 19, 7:04am
Blow off valve or waste gate!
bevharris1938,
Nov 19, 7:06am
waste gate
kwkbrk,
Nov 19, 7:07am
Is that strictly true mugen ! If its external but plumbed into the exhaust its legal I thought. Even if its external and plumbed to atmo, but vents behind the rearmost passenger door its also legal I thought, provided theres no excess noise issues. I thought illegal only if plumbed to atmo then dropped straight to the ground .
bevharris1938,
Nov 19, 7:09am
Mine aint plumbed into anything , straight into the atmosphere
Nov 19, 7:09am
Correct.
kwkbrk,
Nov 19, 7:10am
Just for the record bevharris BOV`s are important for turbo applications . and not all of them are noisy, they certainly don`t have to be. And external wastegates are pretty much useful in high boost applications only, where there is difficulty in maintaining stable boost control otherwise.
zooki007,
Nov 19, 7:11am
External waste gates are legal but they now have to be certified. And the dump pipe must be plumbed into the exhaust or run to the back of the vehicle and have its own muffler.Any modifications to a std waste gate must be certed now.
Nov 19, 7:11am
Is that what some people do! What a waste of time.
bevharris1938,
Nov 19, 7:12am
Car is a rx7 with to4e turbo ,running .6 bar boost. Apexi power FC fuel management.
kwkbrk,
Nov 19, 7:12am
In which case you`re lucky but running the risk of a pink sticker . though again I`m not certain what the situation is if it vents at the rear of the car .
kwkbrk,
Nov 19, 7:14am
No argument from me about that ! bevharris . .6 bar doesn`t make it necessary to me. I`m talking more like 2 bars + .
bevharris1938,
Nov 19, 7:16am
Owe , ok kwkbrk , thanks for the info , they guy that had it before me put all this shit on it , i like the noise off the wastegate but that BOV , over that
Nov 19, 7:17am
6 bar!
kwkbrk,
Nov 19, 7:27am
. ha ha . 0.6 bar I think it says ! bevharris . get the BOV plumbed back into the intake, it will shut it up and the car will probably go better ! As for the external . I agree about the sound but it will get you into trouble at some point !
thegravelracer,
Nov 19, 9:06am
yeah na !
crzyhrse,
Nov 19, 10:00am
And that is the reason it's the correct convention to show a leading zero on all figures <1. 0.6 Bar.
pollymay,
Nov 19, 3:57pm
*low boost* The lower your boost the more air through the wastegate especially lower boost on a smaller turbo. The wastegate will only be slightly cracked if you are boosting high cause most of the exhaust will be directed through the exhaust turbine. High boost your biggest issue is spikes which an electronic boost control can be set to manage.
bevharris1938,
Nov 19, 4:14pm
Thanks for your info guys , but getting back to the main question , why to local garages issues a WOF with and external waste gate vented to atmosphere !
p_rock,
Nov 19, 4:16pm
They gotta be plumbed back don't they! If it got a pass, then issuer not doing their job really.
bevharris1938,
Nov 19, 4:27pm
Sweet , i'm going back there. They arn't a saftey issue are they when vented to atmosphere !
beblowin,
Nov 19, 4:39pm
not a saftey issue but they sound like crap, would rather listen to a noisy gear drive or gates driven belt drive any day.
zooki007,
Nov 19, 4:41pm
Because either they're slack or they don't know what they're doing. Either way they will be caught out in the end and those with WOF's can be recalled to be reinspected.
Turbos 101 explains pretty much everything you need to know about turbos.
