Hi all, am needing to replace/upgrade the old points igntion would I be better to: *Fit a pertronix kit to the old bosch dizzy *sort out a mallory twin point dizzy I have *get a cheap-o afterburner/procomp HEI *try to get a vk/vl v8 HEI!
Any advice! thanks
whqqsh,
Nov 23, 3:42am
never had a 308 but other V8s Ive always used Mallory dizzy with the pertronix ignitor kit, & I wouldnt go near any pro-comp stuff, its total rubbish!
typhoon666,
Nov 23, 4:04am
Ya mallory with the petronix kit is the way to go.
patiki1,
Nov 23, 5:42am
Mallory with the petronix kit is good because you can regraph itand its has adjustable springs.MSD is also a good choice.
dave653,
Nov 23, 7:41am
x1
Std Bosch HEI, was made for them! Just make sure you get the Bosch HEC 716 coil. Also, they come from the WB-VH Commy, 253 and 308, and the dizzy has to be installed 'backwards' for clearance. Aftermarker dizzys and manifolds don't always fit without some grinding.
guest,
May 27, 5:12pm
Going bosch hei is the plan!
