Hi everybody. We have a Ferrari in storage at my work with a flat battery. Where abouts is the battery on a 2002 Ferrari. Sometimes on european cars there is at least a positive terminal to connect battery pack to and the negative terminal to the engine block even if the battery is buried within the car out of sight. I cant find either. Thanks in advance.
dent,
Jan 23, 9:47am
not sure but have u checked under the rear seats and boot
neo_psy,
Jan 23, 9:53am
What model Ferrari would help.
pandai,
Jan 23, 9:53am
Have a look behind the passenger's footpanel.Also check the front storage compartment, there might be a kill switch there to double check.
tuttyclan,
Jan 23, 9:54am
Its a two seater and have looked under and behind and in front the driver and passenger seat. I have checked in the front boot and around the rear engine.
tuttyclan,
Jan 23, 9:56am
Pretty sure its a 360
tuttyclan,
Jan 23, 9:57am
Only 18,000 km lol
neo_psy,
Jan 23, 9:58am
I think I read they're under the passenger footwell.
our ferrari batteryyou have to take the right front wheel off and cover.you can charge a battery by going in to the motor. on the right above the wheel arch there is a boxabout 6 inches square. task off the cover and there is three cables connected. put the red lead on the middle cable. the black cable goes on the cross bar.
