hi all, i have a 1990 mitsi pajero, 3.0l v6 petrol, owned for about 5months, and its makeing a ticking sound which is driving me crazy. tried oil change etc. it sounds like its comeing from the bottom of the engine. metal sounding, if u rev while in park, becomes very lound and fast. any help or advice would be greatly appreciated. cheers
carcrazy8,
Dec 2, 10:37am
try Pro-Ma MBL8if you think its noisy lifter, sorted my v3000.
mellisa2000,
Dec 2, 10:49am
bearing knock, big ends. Engine needs a rebuild.
Dec 2, 6:35pm
Sell at as parts or as is where is. Buy a new car.
mrfxit,
Dec 2, 6:43pm
Has the sound got a high pitch tick or a low pitch thud OR is it a tenor or baritone
mm12345,
Dec 2, 8:32pm
Please don't get all tecchy in here ;-) As soon as someone posts a question with a vague description of a symptom of what may or may not indicate a big problem, please stick to the standard response - advise them that the absolute worst case scenario is the most likely one. Wonder if they're like this in health forums; Q"hey, I've had a headache for three hours - any idea what's causing it!" A " gotta be a neuroblastoma, and if it's big enough to be causing headaches, get your affairs in order now - you've only got days left".
mrfxit,
Dec 2, 9:37pm
LMAO . Sweet
ozz1,
Dec 2, 9:41pm
ohdearpajero V6 ticking.!time bomb.run for the hills
mrfxit,
Dec 2, 9:46pm
LOL probably not. Same engine as I had in my Galant, started ticking really bad (more of a clatter) & did flush/ oil change/ lifter additive & it was fine for the next3 years I had it.
Dec 3, 1:18am
A 3 litre V6!
mrfxit,
Dec 3, 1:26am
Yep, 3ltr SOHC 6G72 1988 GLX Galant 5 speed
rocketman27,
Dec 3, 6:30am
hi, its a high pitch tink.cant hear while driving the car, but very loud when in park. its an auto, 6g72
shane038,
Dec 3, 6:47am
Loose converter bolts!
phillip.weston,
Dec 3, 7:07am
V3000.
mrfxit,
Dec 3, 7:12am
yep, still got the 5 speed box here.
n3d4sp3d,
Dec 3, 9:41am
just add 600ml of proma shel be sweet
rocketman27,
Dec 4, 3:55am
where would the converter be located! cheers
rocketman27,
Dec 4, 3:56am
ill try this proma stuff, but where do i buy it from!
snj11,
Dec 4, 5:46am
Not sure in auckland, but BNT in chch stock it, its about $40 for 1 dose , but it works
n3d4sp3d,
Dec 4, 6:22am
ur local mitsi garage will have lots in stock
the-lada-dude,
Dec 4, 6:53pm
he said from the bottom of the eng ! take the friggn piece of crap to a motor garage and get an opinion on damage or 2 - 3 opinions, then comeback to this site and someone will have the right advise on how to tackle the problem
mrfxit,
Dec 4, 8:01pm
Yes by all means get a garage to check it over but in the meantime
. (have seen this) . Check all the belts for tension & fan to covers clearance Make sure theres no cables hanging down & touching the belts /fan or exhaust system If you are able to do this, check the engine mounts for broken/loose rubbers,
mrfxit,
May 2, 7:11am
Possible but rare
