ok where to startMy heater tap started 2 leakall goods found out it wos corroded in half! So got a new hose and heater tap. Gave the radiator and block a gud flush out since it never been changed put it all back 2gethieradd the water in started it waited for the water 2 go down a bit then added sum more waited then it died didnt think nafin of it at the time. Then started it again. Undone the bass nut to let all the air out. then died took it to work wos going well then the missis came picked it up checked water still full a goods day work lol . got home and she said it keeps on stopping ok on saturday started it up 2 min checking to to see any water leaks the stalled took it for a dive and now it feel like it waits to stall if you dont haveyour foot on the gas peddal took it to get some gas stalled again grrrr half a tank later it keeps stalling.Asking sum friends of mine. (A), it be the fuel fitter (B),check coil pack connectors or (C) last but lest of all the cranksensor as these are the problems cause by stalling grrrr but then got told it may be a numder of things as well!
Dec 4, 6:30am
Here's your problem ^^^^^^.
Dec 4, 6:35am
While you're at it, I suggest you do a spell check on these words ^^^^^^^^^.
gooddealz2,
Apr 29, 1:47am
Oxygen Sensor
