Does any body know if there is a way to get fault codes out with out taking it to someome who has the appropriote machine! Car is 1993 Mitsi Galant VX, 2.0V6
phillip.weston,
Dec 5, 8:32pm
yep - let me know your e-mail address and I'll send you a PDF when I get home from work. All you need is an LED, a small peizo-buzzer or even an analogue multimeter.
snj11,
May 8, 7:47pm
Hi Phillip, thanks for that, i got it put on a scanner today, turns out it was crank angle sensor causing the problem
