you'll find all the codes there somewhere.and some helpful peeps too
mcholden1,
Dec 10, 1:23pm
hi my commodore comes up with the fault codes 23, 29, 59, 96 how do i go about fixing these problems and what are they cheers
kingfisher21,
Dec 10, 1:38pm
23 Air Temp Sensor (Voltage High) 29 EGR Position Sensor Fault 59 Check it again, can't find that one 96 A/C Pressure Sensor Fault
I suggest you clear them all and drive for a few days and check again.
mcholden1,
Dec 10, 1:41pm
how do i clear them just unplug the battery thanks
kingfisher21,
Dec 10, 1:48pm
Yup, for at least 10secs, make sure you have the code for your radio though.
mcholden1,
Dec 10, 1:50pm
sweet its ok its a aftermarket one
mcholden1,
Dec 11, 1:53pm
been driving around for a bit now and error codes still the same
kingfisher21,
Dec 11, 2:13pm
Hmmm, strange, non of those faults are really related to each other, possibly a faulty ECU but thats normally pretty unlikely on a Commodore.
mcholden1,
Dec 11, 2:59pm
the clutch on the ac pump doesnt engage and i have replaced the air temp sensor so have no idea
mortluby,
May 25, 12:56am
Not sure about that generation but we've had 2 VZ ECU's go as well as one on a Rodeo, not bad considering we have 5 VZ's and 1 Rodeo.
