Mazda capella brakes
hardenbol, Jan 31, 6:04pm
my mazda has a shuddering when you brake what could this be
andrea_w, Jan 31, 6:09pm
Quite a few things.
You need to be more specific, under what conditions do you notice the shudder!
Between X and Y speed!
While braking! etc
hardenbol, Jan 31, 6:11pm
noticed it quite bad today when breaking going down a steep hill hubby said it was under heavy breaking.
andrea_w, Jan 31, 6:13pm
It could possibly be a warped disk
I'm sure others will have suggestions too!
hardenbol, Jan 31, 6:17pm
if it was a warped disk would this get picked up at a warrant.it has allways had a shudder on breaking.
carkitter, Jan 31, 6:19pm
Not if its caused by a warped disc rotor. If its caused by a worn ball joint or suspension bush then yes.
pandai, Jan 31, 6:20pm
My car has warped rotors at the moment, I only notice it when I'm crawling to a stop, or going quite fast.If it was more noticeable going down a hill, maybe your rotors went out of shape as they got hotter
mellisa2000, Feb 24, 8:41am
It is often the way. One stop or slowing, ok. 2 or more harder stops and the problem will show more and more unless a cooling off period was had. #1, try 3-4 hard stops from 80 or so, in quick succession, and see what happens. If it is noticeably worse, then it is likely warped rotors. MOST likely fronts, very unusual for rears to go.
