does anyone know where the fuel pump is situated on a capella wagan 1998 model. i have no fuel coming through the plumbing. plenty of fuel in the tank. no holes in the lines, fuses good. this is the second time this has happened only the first time we somehow fixed it but we don't know how we fixed it or what the problem was in the first place. i can only assume there may be a loose wire or faulty pump where ever it is !
Jun 12, 7:24pm
Inside the fuel tank. Access panel should be under the rear seat.
writy,
Jun 12, 8:02pm
cheers for that.typical just had to break down on the freezingist day so far.
msigg,
Jun 12, 8:03pm
Sounds like the fuel pump is knackered. If you run them too low or out they will stuff up. sounds like you need a new one.
Jun 12, 8:19pm
more likely a fuel filter thats been on there since the beginning of time and the poor old pump has got sick of all that resistance.
writy,
Jun 12, 9:51pm
where's the filter @ !
Jun 13, 10:14am
On top of the transmission.
guest,
Jun 30, 6:32pm
under rear seat. ill done one before
