Hey guys what do you rekon a reasonable cost would be do have all this work done on a 4g15 dohc lancer. Full service, check all brakes, Spark plugs, fuel filter, alarm and installation, full cambelt replacment including all the seals, tensioners, water pump and antifrezze.
ginga4lyfe,
Dec 9, 10:07am
thats alot of work, expencive too, the alarm alone can cost you around 600 bucks quite easily
jmma,
Dec 9, 10:07am
The same price as the car cost (o:
jasongroves,
Dec 9, 10:08am
Sounds like you may need 2 workshops. 1 for the alarm and install and 1 for the rest. Quite a lot of it could be done yourself if you were that way inclined! (plugs, filters, oil etc).
thunderbolt,
Dec 9, 10:50am
I was thinking 800 to 1k for all that.
ginga4lyfe,
May 19, 1:54pm
a full service would cost you about 300 bucks ( for top of the line oils and platnum/iridium spark plugs) thats including labor, then about 250 for checking brakes, replacing pads and flushing the oil, tons more if the disks or drums need replacing, the water pump cambelt and tentioner i could guess at 500 bucks. The coins add up fast.
