Holden 308
lumpster, Dec 12, 6:45pm
On my 308 v8 red engine on the block its got stamped REDLINE ENG AAD and has no engine numbers on the block is the a way of finding out what year it is and any thing about it!
spoon27, Dec 12, 6:54pm
u can tell ruffle by what gearbox fits it
lumpster, Dec 12, 7:00pm
M21 muncie
spoon27, Dec 12, 7:04pm
u will have to work out if the bell houseing is chev or trimatis if it's chev it a later model motor whats it in if i may ask
schultzie, Dec 12, 7:17pm
the year & a clock will be stamped on the front of the block right above the timing cover.
It will show 2 numbers which represents the day of the month, a letter represents the month & the last number represents the year. The clock represents the time the block was cast. Example: 23F8 = 23 June 1968 or 1978 or 1988. The clock is pretty self explanatory.
lumpster, Dec 12, 7:18pm
Its all gm holden its in a 74 SLR torana (not a replica)
spoon27, Dec 12, 7:20pm
i'm puting a 308 in a 72 lj torana
cfs, Dec 12, 7:23pm
Dont wish to get pedantic - but the M21's were a copy of a muncie
lumpster, Dec 12, 7:23pm
I have 4 D 4 then 8 on the clock.
schultzie, Dec 12, 7:32pm
4 April 1974.The engine # should normally have the prefix HZ or HT for the SLR. Im assuming its a 74 like the motor!HT is the prefix for the models that had L34 type heads. Does the engine look any different from a normal 308! To have actual words stamped on the ID pad is unusual unless the block is a special casting or been modified etc
lumpster, May 30, 2:44am
The engine has L34 heads and it has id pads on both sides of the engine with the same redline eng aad on both sides! i dont know if its any different to other 308s
