Subaru ppl help
tegndub, Feb 6, 7:28am
i have a 97 gt twin turbo legacy it hasnt been run in 2 weeks now its idoling funny and missing heaps any tips! have tried taking it for a good driver but it dies all the time
lookoutas, Feb 6, 7:44am
Sounds like the coil/s are sparking out.
Have a listen, or start it in the dark and have a look.
Might need to pull them out and clean them.
Auto sparkie here wrapped insulation tape around mine and it lasted for ages. Then put some more on - cheaper than new ones
mechnificent, Feb 6, 7:58am
Can you describe the funny idle a bit better!
Is it too high, too low, varying up and down!
if it's idling high and missing then you probably have a sticky idle control valve. it may need cleaning or it may come right after a few stops and starts and a few runs. cleaning is the real cure though.
mechnificent, Feb 6, 8:00am
Oh, just read the dies all the time bit.
You should extract trouble codes then. have a read here.
http://codes.rennacs.com/
tegndub, Feb 6, 8:55am
there oil in the blow valve pipe 2
likit, Mar 16, 2:58am
Find the nearest cliff,that should fix it.My son has one of these & they consume money like you wouldn't believe.He admits its the biggest mistake he ever made but he's only 19 & had to have a turbo jappa,told him to stick to V8'S
