Sercurity code for radio 98 xh panel van falcon
bumblebee13, Dec 19, 8:29am
anyone know it
a.woodrow, Dec 19, 8:30am
9845
thunderbolt, Dec 19, 8:32am
Damn dyslectics, it's 8954
a.woodrow, Dec 19, 8:33am
unless it's blue - in which case it's actually 4598
bumblebee13, Dec 19, 8:35am
its red thanks :) hopefully this works
thunderbolt, Dec 19, 8:35am
Sorry, i assumed it was red.
bumblebee13, Dec 19, 8:37am
apparently it only has one to six digits !
thunderbolt, Dec 19, 8:39am
You will need to obtain the code from your local Ford dealer.
a.woodrow, Dec 19, 9:16am
Don't listen to this ^^^^
Red ones are 696918
thunderbolt, Dec 19, 9:19am
Not 816969!
The code must be entered by viewing the screen via a mirror.
a.woodrow, Dec 19, 9:22am
Nah fool its voice input - you hold the power button and speak the code in
thunderbolt, Dec 19, 9:30am
Hmm, The car is Australian, but the stereo is possibly of Asian origin.
What accent will be required!
a.woodrow, Dec 19, 9:41am
Should be ok with either - there are a lot of asians in australia now so they would have programmed to recognise both. only problem will be if it was sold new to maori owners in nz - in which case it will have been set at the factory to only respond to maori numbers as additional security
nativewun, Dec 19, 12:12pm
Would almost sound Chinese wouldn't it!
Ono, Iwa, Ono, Iwa, Tahi, Waru - 696918
LMAO
mellisa2000, Jun 21, 2:41am
Bumblebee, you will have to go to the local Ford Franchise, with reg plate # to get the code. If you can get the radio out, (easy job) the code can be obtained from the serial number also.
If you are lucky, it will be written in the hand book. Or on the underside of the radio.
Fish.
