Tecumsen drive engines--an ybody work on em!
smac, Feb 9, 1:47pm
A&E! ;)
bigjerry, Feb 9, 1:54pm
me buddy, i have done a bit on these, lets talk anyway
ema1, Feb 9, 1:58pm
TECUMSEH named after a North American Indian Chief.
The name ends with H not N
Go Kart specialist or motorbike shop guys would be a starter I'd say.Good luck with gettin em started early .you'll need it!
mechnificent, Feb 9, 4:33pm
Those weights are probably meant to have a spring that goes around the outside ofthem to keep them in. There should be a bearing in one part too. presumably the drum in this case.
mechnificent, Feb 9, 4:34pm
There should also be a hub that drives the six weights around, a hub with either slots or tangs on/in it.
mechnificent, Mar 29, 10:10pm
And the drum should have a bearing or bush so it can idle. perhaps that disintegrated and the drum dragged over to the side and rubbed on the clutches!
