can someone please tell me if the rear leaf spring's from 2002 would fit into a 1995! thank's!
mrfxit,
Feb 11, 6:40am
Proberly not directly Are you sure BOTH vehicles are leaf springs Best idea is to use the newer springs to REBUILD the old set. Been there done that. If you don't have half a clue on what to do then DON'T do it. It's not a hard job but does require some logical knowledge
Tools needed are an oxy/acet set , /angle grinder / socket set /Jack stands/ trolly jack/ CRC & some grease / possibly new bush's
vornyk,
Feb 11, 7:13am
cheer's man, both are leaf, andyup i dont have a clue, thanks again!
mrfxit,
Feb 11, 7:20am
Measure from center of front eye to center of leaf (bolt in center)/ then from center of leaf to center of the leaf back end. Measure width & height of the total set of leaves 5 or 10 MM difference is ok with the front measurement 10 to 20mm is ok with the back measurement Over that could be asking for trouble
You MUST have at least 2 FULL threads showing outside the nuts after the new leaves are fitted
r15,
Feb 11, 8:21am
i would say with reasonable knowledge, but not facts that they most likely will fit. the hilux went largely unchanged in this perios
mrfxit,
Feb 11, 9:37am
Possibly is all I can say Main models/ Sub models / short run models/ imports (aussie & Japan) Sometimes they do change the silliest of things for even sillier reasons
Tho in saying that . I brought Sr5 springs for my 88 Surf, tho . I did buy them for parts but did bolt in to the Surf. (eye's needed bending up & too many leaves)
vornyk,
Apr 7, 12:08pm
thanks again guys
